XVS650 bone shaker vibration on acceleration
Have recently bought a XVS650 dragstar with Vance and Hines exhaust,
Hypercharger, rejetted carbs. Seems to go well enough away from the lights.
Doing about 44 to the gallon at the mo.
Only problem is there's load of vibration on acceleration accompanied by the
large amount of exhaust noise !! Lovelly !!
Is this normal on a V twin ?
Would the carbs need balencing ?
Feels like it's shaking it's self to bits.
Have heard on Fixya website it could be loose pistons ?? rings worn ??
Just want to make sure I'm not harming her so early on !! :blink:
Doesn't sound right to me - Get it looked at, if I were you.
Sounds like loose piston, check engine mounting bolts to see if any are loose just incase- loud exhaust sounds like a v-twin
Thanks for the replys chaps.
If I use a compression gauge this should show me if one cylinder is worse than the other would'nt it ?? Unless they are both knackered !!
Anyone know what the compression figures should be ??
Thanks. :D
  • 7 months later...
Hi again,
More help required !
Still vibrating on acceleration and on last cruise got 50mpg.
Decided to buy carb balencing gauges to see if that may be the problem.
Bought a Haynes manual but still unclear as it shows how to connect them up and then says "adjust carburettor No1 to match No2 by turning the synchronising screw(see chapter 3)"
Chapter 3 menions the pilot screws ,which I assume are the two nylon headed ones on the right hand side, but then says to make sure the carbs are sychronised before adjusting the pilot scews !
Not very clear but am I right in thinking I'm looking for one synchronising screw to balence the carbs ?
If so anybody found it ??
Thanks,
Gra. :)
50mpg??
I average 48.
50mpg??
I average 48.
Ahh, thanks for that, means I'm getting about average then.
Think I've found the carb synch screw. On the left hand side between the carbs, buried right deep in the middle.
Cross headed screw and looks like a spring behind it.
Will update next week when the vacuum guages arrive.
Just to note, this bike is a 1997 and looks like the vacuum hoses to the hypercharger have never been renewed as the larger one had "cuts" in the bend and the small one to the front cylinder inlet manifold had a 10mm split in it as it joined the manifold !! Couldn't have helped with the vibration sucking in air !
Also noticed that the airbox that fits ontop of the carbs was not fitted correctly, on one the metal strap was not fitted and the other one the rubber lip was not on the outside all the way round, quarter had folded into the inlet.
Again not an ideal seal.
As I said, will update once the guages arrive.
Thanks,
Gra.
Think I've found the carb synch screw. On the left hand side between the carbs, buried right deep in the middle.Cross headed screw and looks like a spring behind it.
Are you sure it's the sync screw and not the idle adjuster?
THAT'S IT !! that's the one I meant, the smaller one, sync screw.
What a great picture--very hard to see on the side stand in the gloom !!
Great informative site ( http://www.650ccnd.com ) for the Dragstar--Thanks Ttaskmaster.
Buy a torch. :lol:
They're cheap as chips these days, 'specially them LED ones.
Buy a torch. :lol:
Thanks Ttaskmaster touch bought !
Carbs balenced, was 10mm out on gauge and seems to have made a difference.
Two hoses to the Hypercharger, which were both split, renewed and no more backfiring.
Seems a little less vibs now so heading in the right direction.
Also noticed the inlet rubber manifolds from the carbs to the heads had cracks in them so covered with high temp. gasket sealent-- seems to have done the trick.
Thanks again for all your help. :)
