Who can identify this XJ550?
chopper667
This post is 3757 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hey good peoples,
Here's my 1983 XJ550 'project' that I have had since last summer with little time to do much to it.
I'd be interested to know if it's a Seca or Maxim, or was that only in the States?
Frame number is 4V8005168, same as engine number. But something don't look right at the back end... I suspect it been chopped, as has most of the electrics, basic 'hillbilly wiring' as the moderator on the XJ Bikes forum called it.
Anyway, here she is in a very rat form... who knows exactly what this?
Link to comment
Share on other sites
Hey good peoples,
Come on, peeps - don't be shy!
Link to comment
I had a '81 Maxim 550, if I remember rightly those are Maxim wheels, but the axle was on the front of the fork lowers rather than on the bottom. So it looks like you've got a Maxim w/ Seca forks and "custom" bodywork. That is also not the stock pipe as it does not appear to have the collector beneath the engine. And yeah, the rear of the frame looks cut to hell. If you are trying to restore it to either Seca or Maxim spec, I would try to find a better example to start with.
Good luck.
Link to comment
Hell now I don't know, looking at an old picture my Maxim only had one disc up front, not two. I don't know about the seca.
Link to comment
Thanks for your reply Tyler... the last thing I wanna do is to restore it back to it's original incarnation, just wanted to know if my suspicions were correct. Plus getting parts would be easier if I knew what the f**k it started out as! Once I've sorted a few bits out I'll get it road legal, ride it around for a while, and then probably tart it up and sell it for a small profit. Then I'll get a real bike!
Link to comment
I have NO idea...... but it could be a very nice bike with a bit of TLC and chopping ;)
Cheers mate! I hope I can get it sorted before it starts turning cold... need to fix the seat, rear mudguard and lights, and add a chain guard for the MOT and then it should be on the road before too long!
Link to comment
those wheels look very much like my rdlc 350 wheels.
That's very true! I'm going to swap 'em for some XS250 customs at some point, cos they look better in my opinion.....
Link to comment
  • 4 years later...
You need to look at the post date, this is 5 years old !!!!
Link to comment
Ha Ha Ha think he was a bit of a 14 hit wonder :crylaugh:
Link to comment
Check out the frame number it will tell you what model XJ550 it is!
Its got standard forks and wheels off a roadster but the frame different under the seat?
Link to comment
This topic is now closed to further replies.
  • Recently Browsing
