DT175E/mx ignition timeing
hey guys how are you ihave a dt 175e i was just trying to find out how to redard the timeing to spec 1.8mmBTDC i under stand how to line the piston i can do that easyly i plan to use a flat piece of steel across the bore with the head removed and a feeler gauge, but what els is involved? when i did the crank seal on the left i lined the magneto base plate up with the two line marks on the uper right hand side and thought nothing more of it until i came across some thing i read in a forum recently, spinning the base plate is this how you alter the timeing if so is it just a case of lineing up the piston to spec then alinging the base plate up with the markers am i on the right track or not any help is allways apreciated thanks guys bye :)
(yamaha owners club member "steptoe1111")
Hi Shaun, quite an ingenious method of fixing the ignition poin there ;)
You are right about your assumptions too, see if the picture helps
...Paul
