XS 400 Fork oil changing tips
Hi, i must change Fork oil on my old Yamaha 1981 XS 400.
Have you some tips to do this job easyly ?
What tools must to have, is there some specific tools ???
I am waiting your informations to do this job.
Best regards from Belgium, infrapista
:welcome: Ipista
is it the dohc xs400 or the sohc xs400?
:welcome: Ipista
It's the sohc xs400 ?
If you have any good tips or special home made tools information to do the job, i want it.
Special thanks from Belgium, infrapista
:welcome: Ipista
Here a picture of my 1981 Velocettised XS400 Cafe Racer
You need to remove the plastic cap, and push down the metal button while removing the circlip with a couple screwdrivers. It takes a lot of force to push it down. I wedge in a 3/8" drive ratchet with 1/4" adapter and tiny metric socket between the handlebar and the button, and it'll sit there solid while you work around it:
Ok, thank you very much for this tip.
I'll try it this week-end.
What kind of oil use you in your fork ?
Many thanks, infrapista
Also make sure to loosen that upper pinch bolt. It will compress the tube enough to not let the cap pop out.
