September 9, 200916 yr Can this be replaced with the cam cover in place, or am I going to have to pull the engine to replace an $5 part?
September 9, 200916 yr Moderator Can this be replaced with the cam cover in place, or am I going to have to pull the engine to replace an $5 part? its getting the bugger out, unless you can use a thin screw and pierce the rubber, twist a bit to bite in, then pull out. replacing is a simple matter of driving a new one in!! if the screw don't work, you only need to take the cam cover off drewps
