September 6, 200916 yr looking to upgrade my brake calipers to the blue spot design. but not sure what fits? do they have all the mounting pitch or do i need to get a certain model i.e thundercat, r6, r1, fazer its for my 1991 fzr 1000 exup with upside down forks!. any help would be great!
September 14, 200916 yr Alrite mate the blue spot calipers as i'm aware are the same dimensions no matter what they came of eg the space between the bolt holes are all the same... I think the only differences between some of the callipers is that some of them hace what appears to be a balnce pipe or something.. lol not quite sure what the little pipe does :S I've got a set on my foxeye 600 and they bolted on no problem, but i think if you've got the usd forks you'll need 2 modify the bottom of the fork with a grinder to make clearence for the front edge of the calliper... Hope this helps
