September 3, 200916 yr hello ,i have a dt 125 mx ,with a 1979 yz engine,.i went to ken hall motocross at the weekend an noticed that a lot of the bikes ,,twin shock had boost bottles coming from the reed block,,,,,why?????i ,if they serve to add more power i was thinking of putting an early lc reed block on a dt mx barrel,as they had as said bottle.do they increase power. cheers
September 3, 200916 yr hello ,i have a dt 125 mx ,with a 1979 yz engine,.i went to ken hall motocross at the weekend an noticed that a lot of the bikes ,,twin shock had boost bottles coming from the reed block,,,,,why?????i ,if they serve to add more power i was thinking of putting an early lc reed block on a dt mx barrel,as they had as said bottle.do they increase power. cheers Their for keeping your Lucozade sport in
September 4, 200916 yr Moderator hello ,i have a dt 125 mx ,with a 1979 yz engine,.i went to ken hall motocross at the weekend an noticed that a lot of the bikes ,,twin shock had boost bottles coming from the reed block,,,,,why?????i ,if they serve to add more power i was thinking of putting an early lc reed block on a dt mx barrel,as they had as said bottle.do they increase power. cheers They increace mid range, as the piston moves there is a time although breif where the charge is moving into the upper cylinder from the cases. Where the reeds are not actually shut and the blow back is held in the boost bottle. Then on the next cycle there is charge ready and waiting to fill the cases. As to real benefit. Dunno really. Supposedly boosts mid range. The balance pipe on LC motor inlets works in a similar way.
