August 30, 200916 yr are these foam filters washable yes ,use soapy water then rinse then allow to drip dry.
August 30, 200916 yr Author water and soap sounds good, iv read that you should clean with solvant (not sure if i like this )and oil it afterwards. do you oil it or put it in dry
August 30, 200916 yr water and soap sounds good, iv read that you should clean with solvant (not sure if i like this )and oil it afterwards. do you oil it or put it in drylightly oil it,clean engjne oils ok,put filter in plastic bag with oil on filter then rub it in.
