August 29, 200916 yr Hey guys, this is my first post here so hope this goes well. Just bought a Yamaha XJ600 1992 as my first bike, planning on doing it up a bit while i'm passing my tests. it's got virtually no oil so i thought i would start with an oil change and replace the filter, anyone know what oil i need and what the filter part is? cheers.
August 29, 200916 yr Hey guys, this is my first post here so hope this goes well. Just bought a Yamaha XJ600 1992 as my first bike, planning on doing it up a bit while i'm passing my tests. it's got virtually no oil so i thought i would start with an oil change and replace the filter, anyone know what oil i need and what the filter part is? cheers. Alex ok the XJ600 will need some 10W40 motor oil from memory 3200 cc (3.2 L) and a http://www.knfilters.com/search/product.aspx?Prod=KN-144 should do fine for the filter ... just watch undoing the filter bolt Regards Jim
August 29, 200916 yr Author Alex ok the XJ600 will need some 10W40 motor oil from memory 3200 cc (3.2 L) and a http://www.knfilters.com/search/product.aspx?Prod=KN-144 should do fine for the filter ... just watch undoing the filter bolt Regards Jim Thanks very much for the quick response. What do you mean by "just watch undoing the filter bolt"? also any ideas where i might get the filter on a sunday?
August 30, 200916 yr Thanks very much for the quick response. What do you mean by "just watch undoing the filter bolt"? also any ideas where i might get the filter on a sunday? Hi Alex, the oil filter is set between the front exhaust pipes so it is very exposed to road dirt, which tends to corrode the bolt to the filter bowl. As the bolt has a small head in relation to the size of the bolt it tends to 'round off' unless you give it a 'shock' first and use a good quality socket to undo it. As where to get a filter from on a Sunday I could not suggest anywhere bar the breakers in Upton Upon Severn Worcestershire as I know they stock them and are open Sunday till mid day but not knowing where you are this is the best I can do Regards Jim
August 30, 200916 yr Author thanks for your help, managed to get everything i needed and job completed.
