August 21, 200916 yr Hello! Just registered here, and wants to check if anyone knows of any good tricks to tune the Yamaha YZF-R125. Well, I have already fitted the Power Commander 5 and Devil slip-on exhaust for performance, but still it only does 135km/h.. Anyone know of any good maps for the power commander or any other tricks to make it go any faster? (Except new cylinder). Will add some pictures aswell! Would also appreciate any links to sites where I can buy performance parts and accessories. Thanks! Greetings Kim
August 21, 200916 yr it may stil be factory restricted check air filter box and inlets im sure some on will come a long and give a better answer
August 21, 200916 yr Author it may stil be factory restricted check air filter box and inlets im sure some on will come a long and give a better answer Airfilter box, or the airfilter itself? Not sure if i know what inlets are, but ok.. Thanks!
August 21, 200916 yr Airfilter box, or the airfilter itself? Not sure if i know what inlets are, but ok.. Thanks! airfilter box it should have a snorkle that can be removed but this will require a remap also you should get a K&N air filter also the inlet is where the injector body meets the manifold there is sometimes extra flaps on the rubber bit that restricts fuel flowbut not sure on this, also does ure bike revv freely or does it stop at like say 7000rpm ?
August 21, 200916 yr Author airfilter box it should have a snorkle that can be removed but this will require a remap also you should get a K&N air filter also the inlet is where the injector body meets the manifold there is sometimes extra flaps on the rubber bit that restricts fuel flowbut not sure on this, also does ure bike revv freely or does it stop at like say 7000rpm ? I see.. The workshop that fitted the power commander mapped my bike when they ran it at the dyno.. It stops at 10,500rpm, it is limited. But the red starts at 10,000.. I am looking at a BMC air filter atm, do you think that would do any good?
August 21, 200916 yr I see.. The workshop that fitted the power commander mapped my bike when they ran it at the dyno.. It stops at 10,500rpm, it is limited. But the red starts at 10,000.. I am looking at a BMC air filter atm, do you think that would do any good? ok well its not limmited then buy rpm as long as you can reach redline and the air filter looks ok but never heard of them so K&N still ure best bet also make sure you remove the inlet snorkel as this will aid greatly with air flow but you must get it redyno'd to make use of these improvments how much they improve is hard to tell maybe from 1-3bhp
August 21, 200916 yr Author ok well its not limmited then buy rpm as long as you can reach redline and the air filter looks ok but never heard of them so K&N still ure best bet also make sure you remove the inlet snorkel as this will aid greatly with air flow but you must get it redyno'd to make use of these improvments how much they improve is hard to tell maybe from 1-3bhp K&N does not produce any air filters for my bike at the moment. I really do not know what the "inlet snorkel" is, but I will look into it! Thank you very much
August 21, 200916 yr K&N does not produce any air filters for my bike at the moment. I really do not know what the "inlet snorkel" is, but I will look into it! Thank you very much ahh ok mybe try pipercross they might do one and the inlet snorkel is in the air filter box and looks like the tube in this picture but should not atache to any thing and leed straight out or to a tube that goes to the front of the bike
August 21, 200916 yr Author ahh ok mybe try pipercross they might do one and the inlet snorkel is in the air filter box and looks like the tube in this picture but should not atache to any thing and leed straight out or to a tube that goes to the front of the bike Will look into it! Thanks
August 24, 200916 yr Author come on people?!?! anyone heard of a yzf-r125 with turbo then? or has got a map for Power Commander 5 mixed with Devil Slip-On exhaust?
January 17, 201015 yr come on people?!?! anyone heard of a yzf-r125 with turbo then? or has got a map for Power Commander 5 mixed with Devil Slip-On exhaust? Get your self over to the R125 forum. The people there have a vested interest in you, your question and finding you an answer we all have an R125 . http://www.yamahar125.com/forum/index.php Also, becuase the R125 is a 4 stroker, it has been designed to produce the 15hp at the flywheel, to get more out of this engine requires tuning and stressing the standard components. There is no washer to remove from the exhaust or YPVS valve in the exhaust port to turn etc etc. There is a 150CC cylinder available from Yamaha and a 180CC cylinder from malossi which may be a good next step for your bike, but like I said get over to the 125 forum and youll get lots more answers to your questions. Blinding
January 22, 201015 yr If your that bothered about top end just change your gearing. You'll lose acceleration though probably quite a bit on a little bike.
January 23, 201015 yr K&N does not produce any air filters for my bike at the moment. I'm 99% sure that if you phone k&n directly they will make any airfilter you want, they will ask you about size's, shape etc and make you one to fit. just because it isn't on the list doesn't mean its a no go. Welcome to the forum btw. Vez
