float height settings
Anyone know the float hieght settings for a '84 XS400 Maxim? One side is 20mm and the other is 22mm but the manual wants to use an external method to measure, problem being I don't have the float nipples to test from on the bowls.
I shoved a clear washer tube in the lower float bowl with the carbs off the bike and clamped level. easy to do and was 2mm from top of float bowl as per specs.
drewps
