Posted August 17, 200916 yr Any tips on how to seperate the cylindr block from the crankcase? I want to change the rings and fit a new base gasket but it wont budge!
August 18, 200916 yr Any tips on how to seperate the cylindr block from the crankcase? I want to change the rings and fit a new base gasket but it wont budge! Hi, you need to hit the barresl in the 4 directions with a rubber mallet if this does not work goto plan 2 I'll fill in plan 2 if plan one doesnt work the problem you have is the dowels in the cylinders/barrels have some intermetalic corroision and just need some brute force & ignorance Regards Jim
August 23, 200916 yr Author Hi, you need to hit the barresl in the 4 directions with a rubber mallet if this does not work goto plan 2 I'll fill in plan 2 if plan one doesnt work the problem you have is the dowels in the cylinders/barrels have some intermetalic corroision and just need some brute force & ignorance Regards Jim Thanks Jim, wont need plan 2, just persevered. it took me 3 hours as the bloody studs were seized into the barrels with the accumulation of muck. Cheers
August 23, 200916 yr Moderator Thanks Jim, wont need plan 2, just persevered. it took me 3 hours as the bloody studs were seized into the barrels with the accumulation of muck. Cheers Damn...I was dying to see plan two!!
