right i fitted mini bulb indicators to my bike and the 21w bulbs kept blowing the fuse so got some 10w bulbs (same watage as the stock ones) and they now flash realy fast but dont when on hazards
does any one know what could cause this ?
thanks need a quick answer as i dont have another form of transport
had the same problem with mini-indicators and put 21watt bulbs in the back and left the 6 watt in the front. this cut the flashing speed to normal but it didnt blow any fuses. :blink:
is this the same set-up as you have tried? ;)
yeh ment to post back thats what i did and i blew the fuses with all 4x21w's runing idk it was somthing but fuses are fine now and i have 21's in the front and 10's in the back and it works fine :)
put the 21 watts in the back as they will be brighter so less chance of being rear-ended ;)
i put mini indicators on my r6 and they also flashed really fast so got some in line resistors and they worked fine but get very hot if you leave indicator on so i fitted a new indicator relay from motrax straight replacement for yamaha one so thats what i would do, hope that helps and nice job on your bike
