YZ question 1999 model
1999 yz 250 ~~Ok im 30 yrs behind on tech so im needing to know a few thing, the kids bike I thought had locked up, upon removal of the clutch side cover I found the KICK return spring bent wedged into the clutch drive gear, so tight I had to dremal cut it out, no damage to gears, ive ordered a new spring, Can I intall new spring without removal of basket? ALSO, the spring end that mounts to case? where does it go exactly, ive got nothing for referance, IF ANYONE has a pic of spring pos. that would be great.
also on same side of clutch side cover theres a power valve?? remember im a little behind on this stuff. What exactly does it do. Is there any particular lineup to gears when I reinstall cover??
outer view
