Reid Posted August 13, 2009 Share Posted August 13, 2009 i have a 1978 DT400 i just picked up , wiring is all messed. i got a wiring diargram from a fellow member but im stumped, im not going to use any lights or anything, so what are the basic things that need to be hooked up for it to run without a battery? or run at all for that matter. Link to comment Share on other sites More sharing options...
Moderator Airhead Posted August 13, 2009 Moderator Share Posted August 13, 2009 You posted this once, dont be so impatient and double post! Link to comment Share on other sites More sharing options...
Reid Posted August 13, 2009 Author Share Posted August 13, 2009 well maybe you could help me! Link to comment Share on other sites More sharing options...
blackhat250 Posted August 14, 2009 Share Posted August 14, 2009 i so what are the basic things that need to be hooked up for it to run without a battery? or run at all for that matter. U"l need to check the CDI [Wired properly 6 wires] the Timing. manual will be of essence. i"v listed CDI .And pulsar coil for this model on fleabay,, a multi-meter will be of assence too Link to comment Share on other sites More sharing options...
Reid Posted August 14, 2009 Author Share Posted August 14, 2009 U"l need to check the CDI [Wired properly 6 wires] the Timing. manual will be of essence. i"v listed CDI .And pulsar coil for this model on fleabay,, a multi-meter will be of assence too how much do you want for the cdi and the pulsar coil? Link to comment Share on other sites More sharing options...
