Posted August 13, 200916 yr i have a 1978 DT400 i just picked up , wiring is all messed. i got a wiring diargram from a fellow member but im stumped, im not going to use any lights or anything, so what are the basic things that need to be hooked up for it to run without a battery? or run at all for that matter.
August 14, 200916 yr i so what are the basic things that need to be hooked up for it to run without a battery? or run at all for that matter. U"l need to check the CDI [Wired properly 6 wires] the Timing. manual will be of essence. i"v listed CDI .And pulsar coil for this model on fleabay,, a multi-meter will be of assence too
August 14, 200916 yr Author U"l need to check the CDI [Wired properly 6 wires] the Timing. manual will be of essence. i"v listed CDI .And pulsar coil for this model on fleabay,, a multi-meter will be of assence too how much do you want for the cdi and the pulsar coil?
