Posted August 11, 200916 yr Hi all A bit of history my second bike a 1992 XJ600S Diversion sat in garage for a couple of months,tried to start it loud click on right hand side,no go.much head scratching replaced faulty starter solenoid.new one ok according to haynes test method.Still no joy next option is replace either relay assy on left hand side of bike,or ignitor unit assy on right hand side of bike. My question is can anybody suggest other options or tests to isolate problem. Thanks in Advance Tunny
August 11, 200916 yr Hi all A bit of history my second bike a 1992 XJ600S Diversion sat in garage for a couple of months,tried to start it loud click on right hand side,no go.much head scratching replaced faulty starter solenoid.new one ok according to haynes test method.Still no joy next option is replace either relay assy on left hand side of bike,or ignitor unit assy on right hand side of bike. My question is can anybody suggest other options or tests to isolate problem. Thanks in Advance Tunny Sounds like youre battery is shagged/or not charged enough
August 11, 200916 yr Take the whole starter motor off and connect it directly to the battery, just make sure the motor, as well as your noo solenoid is working
August 11, 200916 yr Author Battery fully charged every other electrical item works . Starter turns used jump lead to connect direct to battery both on and off bike engine turns over no problems but wont work off button or bumping
August 11, 200916 yr Battery fully charged every other electrical item works . Starter turns used jump lead to connect direct to battery both on and off bike engine turns over no problems but wont work off button or bumping does it just 'click', or is it making a humming noise with the button pressed?, dont hold button for longer than 10 seconds
August 11, 200916 yr Author no noise at all the oil light comes on when you press button but no other signs of life
August 11, 200916 yr no noise at all the oil light goes out when you press button but no other signs of life with oil and neutral light on, it defo' sounds like a prob with the side stand safety switch/or circuit, check this in your 'Heinous' manual bud
August 12, 200916 yr no noise at all the oil light comes on when you press button but no other signs of life I know exactly what the problem is. It happened to my xj600 in April. If you look at the Haynes elec diagram and trace the wire from the starter button(blue/white?) it goes into a block connector before going to the starter relay which is located under the seat on RH side, should be the forward relay out of four. Even though it will look ok but it will be corroded and therefore not making a connection. Mine is a W reg(2000) if yours isn't located there because of being an older model the Haynes manual will tell you where it is. Mike
August 12, 200915 yr Author Hi all thanks for all your help still no joy. Tested all connections and connectivity from starter button to relay assembly tested same for neutral switch sidestand oil pressure and clutch switch. so the only thing left is to replace relay assembly then ignitor unit and see what happens New pads and HEL lines have arrived for ninja so will be busy with that but will let you know when divvy is fixed once again thanks for all help Cheers chaps
August 19, 200915 yr I know exactly what the problem is. It happened to my xj600 in April. If you look at the Haynes elec diagram and trace the wire from the starter button(blue/white?) it goes into a block connector before going to the starter relay which is located under the seat on RH side, should be the forward relay out of four. Even though it will look ok but it will be corroded and therefore not making a connection. Mine is a W reg(2000) if yours isn't located there because of being an older model the Haynes manual will tell you where it is. Mike Same happened to mine, corrosion in the block connector stopped the starter solenoid from being energised. It's very exposed to all the rear wheel spray.
