August 11, 200916 yr Can a stock Yamaha Dragstar screen fit on any Dragstar? Specifically - could I fit a 650 Custom screen on a 1100 Classic? Thanks UD
August 11, 200916 yr Moderator Can a stock Yamaha Dragstar screen fit on any Dragstar? Specifically - could I fit a 650 Custom screen on a 1100 Classic? Thanks UD No. The front ends are different, so the fittings are different.
August 11, 200916 yr Author No. The front ends are different, so the fittings are different. Thanks for the quick answer. UD
September 8, 200916 yr Author Last one (for now). Will a 650 Classic screen fit an 1100 Classic? Thanks for the patience. UD
September 8, 200916 yr Moderator Depends on what make you are talking about. Most makes will fit but you need to check before hand. Genuine Yam ones are also interchangeable between the two. For example the Boulevard screen which is a genuine yam accessory will fit XVS650A DragStar Classic '98-'07 and XVS1100A DragStar Classic '00-'07 Do yer homework first UD before you spend your cash
September 8, 200916 yr Author Depends on what make you are talking about. Most makes will fit but you need to check before hand. Genuine Yam ones are also interchangeable between the two. For example the Boulevard screen which is a genuine yam accessory will fit XVS650A DragStar Classic '98-'07 and XVS1100A DragStar Classic '00-'07 Do yer homework first UD before you spend your cash This is part of my homework ;-) Nice photos btw!
October 27, 200916 yr Author Yes they can.... I thought I'd take a chance at £26 for the windscreen and lower deflectors!
