August 10, 200916 yr Does anyone know how to adjust the handlebars on a 2009 XJ6N? It says in the manual they can be adjusted backwards or forwards by 20mm but doesn't say any more than that. I'd appreciate any thoughts....
August 10, 200916 yr Does anyone know how to adjust the handlebars on a 2009 XJ6N? It says in the manual they can be adjusted backwards or forwards by 20mm but doesn't say any more than that. I'd appreciate any thoughts.... loosen the four allen headed screws, 'rotate' as above, you may also have to adjust your switch sets, same as above!
August 11, 200916 yr Author loosen the four allen headed screws, 'rotate' as above, you may also have to adjust your switch sets, same as above! Brilliant thanks!
