August 10, 200916 yr i just got my replacement rotor from ebc . wow what a nice rotor . here's the thing: it's got counter sunk mounting hole's on the face so how do you mount it ? i understand i can use bolt's with holes for safety wire to mount it insted of locking tab's but what do i use in the countersunk hole's spacer's or washer's ? ive checked and it is the replacement rotor for my bike i just dont understand the hole's ? link: http://www.perfectbrakes.com/products.asp?cat=8012&pg=1
August 10, 200916 yr Moderator i just got my replacement rotor from ebc . wow what a nice rotor . here's the thing: it's got counter sunk mounting hole's on the face so how do you mount it ? i understand i can use bolt's with holes for safety wire to mount it insted of locking tab's but what do i use in the countersunk hole's spacer's or washer's ? ive checked and it is the replacement rotor for my bike i just dont understand the hole's ? link: http://www.perfectbrakes.com/products.asp?cat=8012&pg=1 use thread lock, normally the bolts already have the thread lock on then like this
August 10, 200916 yr You could contact their customer services http://www.ebcbrakes.com/Index.html, or just go with standard rotor screws from yamaha, which look pish!, or you could get Titanium screws from Here, you can safely ignore the 'counter-sink' bit and like Drewpy said 'thread-lock' is a must
August 11, 200916 yr Author thank's for the help guy's . as soon as the new pad's show up im going to bolt her up
