howdy, my kick starts ,ball bearing and washers dont hold the kick arm steady any more ,it swings out when im on the go,i put a new C clip and thicker washer in their to try and pack it but its still the same,also the ball bearing appears to work fine,what can i do other than replace the kickstart.
try drilling out the recess (slightly) where the ball-bearing sits and a stronger spring.
will the bearing not just fall out iff i do that.
there should be a small indentation that the ball-bearing sits into to keep the kickstart in place, its this that you drill.
if you take the circplip and washer off then slide the the kick start off you will see it.
watch when you take it off that the bearing dosent shoot out. ;)
ta ill give it a go.
might have to bush the lever hole as it will have worn oval. needs drilling round and someone to make a bronze bush!
or buy another one from yambits, hvc or PGM
drewps
cheers drewpy chops,ill try the above first and see what happens,
