XVS650 IDLE Trouble
Most XVS's works synchronously when IDLE
but mine wont work that, wynchronisation is okay, but when IDLE times to times stucks and then goes faster, then slows again.
sparks is okay, mixture is 1.5 turns, valves is 0.1 intake, 0.14 out take.
does anybody knows about idle sensor and setups of this sensor?
There's an idle adjustment screw on the left side, near the top of the cylinders.
  • 3 weeks later...
Im going over 30k miles on my bike and do u think i dont know here idle screw is?:)
im talkinbg about another problem.
thank you for an answer
does the problem go away after the bike is really warmed up? Also could be fuel flow, idle jets are sensitive to fuel levels, but i don't know if a XVS has EFI... if you have floats check the height, and that the fuel system is free of debris.
