Patrick Yegor Posted August 9, 2009 Share Posted August 9, 2009 Most XVS's works synchronously when IDLE but mine wont work that, wynchronisation is okay, but when IDLE times to times stucks and then goes faster, then slows again. sparks is okay, mixture is 1.5 turns, valves is 0.1 intake, 0.14 out take. does anybody knows about idle sensor and setups of this sensor? Link to comment Share on other sites More sharing options...
Moderator Airhead Posted August 10, 2009 Moderator Share Posted August 10, 2009 Most XVS's works synchronously when IDLE but mine wont work that, wynchronisation is okay, but when IDLE times to times stucks and then goes faster, then slows again. sparks is okay, mixture is 1.5 turns, valves is 0.1 intake, 0.14 out take. does anybody knows about idle sensor and setups of this sensor? may be a split carb diaphragm? ...Paul Link to comment Share on other sites More sharing options...
