August 9, 200916 yr Just want to check that the spark plugs on the XJ500 is 18 mm and not 11/16" Do you mean the size of the socket to remove the spark plug? If you do then all Japanese models are metric, 11/16" is just slightly thinner than 18mm (about 17.50mm) If you mean the reach then there is not a lot of difference at all. Hope this helps. Mike
August 9, 200916 yr Author Do you mean the size of the socket to remove the spark plug? If you do then all Japanese models are metric, 11/16" is just slightly thinner than 18mm (about 17.50mm) If you mean the reach then there is not a lot of difference at all. Hope this helps. Mike I ment the socket yes The reason I was wondering was that it is very difficult to find a 18 mm spark plug socket in Sweden, we have 17, 19 and 21. So therefore I started to suspect that it was a 11/16" instead, since that would not really be detectable when we removed plug 1 and 4 with a 18 mm wrench
August 10, 200916 yr I ment the socket yes The reason I was wondering was that it is very difficult to find a 18 mm spark plug socket in Sweden, we have 17, 19 and 21. So therefore I started to suspect that it was a 11/16" instead, since that would not really be detectable when we removed plug 1 and 4 with a 18 mm wrench It doesn't have to be a spark plug socket. Try an 18mm box spanner or a long socket. In fact thats what I use on my bike so I can use a ratchet with it. Mike
August 10, 200916 yr Author It doesn't have to be a spark plug socket. Try an 18mm box spanner or a long socket. In fact thats what I use on my bike so I can use a ratchet with it. Mike Uhmm, I found one 18 mm spark plug socket, it wasnt that hard once I started to look There seems to be no 11/16 but a 13/16 instead that is a spark plug socket, but I will use my new 18 mm
