new member 1976 DT125c
Hello, I just got myself a 1976 DT125c. The clutch is really hard to pull. I checked that cable is fine and the pin is straight.. What else could it be??
Thanks!
Serge
Grease the cable internally with oil and lubricate the pivot points at the handle. Make sure it is not binding on it's way to the transmission. If that doesn't do it then the springs on shifting rod could be the problem. Bent parts, aftermarket racing springs, or other peccadilloes can cause hard clutch operation. Sometimes you have to open stuff up to see what is what.
