Posted July 30, 200916 yr Just a few probs with my dt.Does anyone have any ideas why the bugger wont spark? I have assembled it from a few spare parts, however the cdi matches the loom and stator (6 wire). Am getting some form of life from the magneto and have a new plug and supressor. Help!. Cheers Jeb
July 30, 200916 yr you might want to unplug any lights it has if youre running it without a battery, if its not that you got a bogus cdi/coil but id think it was the cdi.
July 30, 200916 yr Moderator Just a few probs with my dt.Does anyone have any ideas why the bugger wont spark? I have assembled it from a few spare parts, however the cdi matches the loom and stator (6 wire). Am getting some form of life from the magneto and have a new plug and supressor. Help!. Cheers Jeb Hi Jeb Try unplugging the kill switch and the ignition key switch then check again. Try another plug, Check the resistance values of your magneto source coil = 420 ohms +- 10%............Brown to chassis Check the resistance of the magneto pulse coil = 12.4 ohms +- 10%...........White / Red to chassis Check the resistance values of the ignition coil, Primary = 1.0 ohm =- 15%, secondary = 5900 ohms +- 20% ...Paul
July 31, 200916 yr Author Hi Jeb Try unplugging the kill switch and the ignition key switch then check again. Try another plug, Check the resistance values of your magneto source coil = 420 ohms +- 10%............Brown to chassis Check the resistance of the magneto pulse coil = 12.4 ohms +- 10%...........White / Red to chassis Check the resistance values of the ignition coil, Primary = 1.0 ohm =- 15%, secondary = 5900 ohms +- 20% ...Paul Hi Paul, Just tried your suggestions and still nothing; anything further would be most appreciated, apart from the obvious like torching the bastard. Cheers, Jeb
August 7, 200916 yr hi there, dont know if its any help but my mates dt had similar problems, it was all down to his spark timing, might be spouting a load of rubbish bu it might be worth checking it out your statoplate. hope this helps you out
