July 30, 200916 yr Hi, I've noticed on my SR125 that there is a problem with my headlight. Sidelight setting is fine, then I move the switch to dipped headlight and it doesn't get any brighter, but full beam works fine. Any ideas? A friend suggested charging my battery, which is fine I'll just have to buy a charger first. Is it likely to be anything other than a battery in need of a charge? I've had no other signs of flat battery, its starts easily and runs fine. Many thanks, Chris.
July 30, 200916 yr Hi, I've noticed on my SR125 that there is a problem with my headlight. Sidelight setting is fine, then I move the switch to dipped headlight and it doesn't get any brighter, but full beam works fine. Any ideas? A friend suggested charging my battery, which is fine I'll just have to buy a charger first. Is it likely to be anything other than a battery in need of a charge? I've had no other signs of flat battery, its starts easily and runs fine. Many thanks, Chris. i sugest checking the bulb and if thats fine have a look at the switch ( might just be a loose connection )
July 30, 200916 yr Moderator i sugest checking the bulb and if thats fine have a look at the switch ( might just be a loose connection ) +1, there are two filaments in the bulb, have a look with a magnifying glass you may see one broken, if you have a multimeter test them both you should get a reading from each solder point to the metal casing.
August 2, 200916 yr Author +1, there are two filaments in the bulb, have a look with a magnifying glass you may see one broken Excellent diagnosis you were spot on, ordering a new bulb now, thanks for your help guys!
