hi, just snapped the bleed nipple off on fz600 rear caliper 1987, tried to drill out and use easy out but that has snapped of
inside , can not drill out easy out as it is hardened steel and to top it all i got stung on the neck happens in threes, tried to find caliper with part finder not one call, does any one think it can be repaired or are there any other rear caliper common to this bike , does any one know if the rear under gaurd number plate section is common to any other model as i can find a good one thanks dave
is THIS
the caliper you're looking for?
as for the underguard i cant help you, you may be able to fabricate something if you are creative
yeah it is the one i saw it this afternoon i was looking for one in better nick its a bit overpriced but when desperate
and i cant find one i may have to buy it thanks dave
it has snapped off flush with the top of the caliper and did not move , i think it will leak as i drill it out to the piston
will i have to re thread it to use this item as it looks bigger thanks.
The combo banjo bolt/nipple is to replace the existing banjo bolt, which connects the brake hose to the caliper. It would be worth checking if your drilling has compromised the caliper, 'cuz if it's still ok, this is the quickest fix.
If you drill out the broken bleed nipple, you will have to be very carefull not to damage the taper seating at the bottom of the hole, as this is where the bleed nipple tightens to stop fluid leaking.
ok i understand how it works now thanks dave
got a spare under-guard if you're still looking dave. plus some other bits from the back-end bodywork wise. giz a shout if you're struggling. also for snapped bleed nipples i've used a plain old stud-extractor to wind them out. drill it as wide as about half way up your extractor tho,-use the thickest one you can without drilling through threads. if you've snapped a drill bit into it it's a job for some patience and a very sharp centre punch- tap it anti-clockwise. i've always found cellulose thinners 100 times better than (and more flammable than) WD40. a little heat (don't use a flame- i use a paint-stripping gun) always helps. is it possible to split the caliper and attack it from the inside?
oh and "spares unlimited" in hull are breaking said bike, they may have some calipers in.
hope it helps!
jim
hi, foamy i got that caliper today the one you sent me a link to ebay i phoned and checked the bleed nipples
where free, and yes you can guess its the wrong caliper, pistons the wrong size caliper to big , it will have to go back
sorry to hear that mate, i assumed it would be the same as it was off the same year/model of bike :\,
yeah, i checked it with bike breakers i think who had the bike before must have adapted it to fit, i phoned them today
and they can have it back, not giving up till i find a good one.
some auto-engineers may have a diamond tipped drill-ream and will drill out the old nipple. Doesnt matter if there are broken off drills etc in there. Then they will helicoil it for you.
thats the route id take, if calipers are scarce.
