Hi all
Would you believe the DT has done the piston and rings again :angry: and it's a diffrent engine.
Any way the thing is I took the head and barrel of(getting good at this) and found rings shagged and piston knacked but what I found strange is there is oil in the crankshaft as far as I know there should be no oil there,as I turn the engine over with the kickstart the crank comes up soaked in oil.Any ideas lads,is it a full strip down and seals or worse as in crack between crankcase and gearbox.
Cheers all
Daz
Hi daz , howz the sun [weve not seen it at all this summer] :(
Now .. the oil u be seeing is gearbox oil, smearing a section of crank [ bottom side wen sitting still] shudn!t be any oil in there.
- i thot it was a case of gearbox oil level too high" . check box level just to make shure" . [coz i thot crank dipping in oil wud coz drag] . wot did the rings then ? lack of two-stroke . did u check pump? or are u pre-mixing.? or u blaming the brother again :lol: [ wot a memory ;) i hav eh] is the barrel scored ???
If you have gear oil inside the crank area you probably have a leaking crankshaft seal sucking oil into the 2 stroke side.
You must have a good seal on both sides of the crank shaft. Do a pressure test.
LOl not me brother this time,the engine was second hand and it did heat seize on me once after a full day running around in really hot weather(went up to 41 celcius last week)but left it for a half hour and was ok,funning thing is I premix myself at 25to1 lovely loads of smoke behind me lol barrel ok so might as well get new crank seals and do it properly.
thanks all
Daz
