dragstardave Posted July 27, 2009 Share Posted July 27, 2009 Ok here we go about a year a go i put a new battery on a 125 dragstar (because the old one had swelled up to bursting point)just had a look and the new one has done the same anybody else had this problem and sorted it out please let us know Link to comment Share on other sites More sharing options...
Ttaskmaster Posted July 27, 2009 Share Posted July 27, 2009 Jeezy..... Sounds like something isn't connected/earthed properly. I think this is going to be a long job of checking all your electrical contacts, fella. Link to comment Share on other sites More sharing options...
dragstardave Posted July 27, 2009 Author Share Posted July 27, 2009 Thanks Ttaskmaster will check that first Link to comment Share on other sites More sharing options...
Ttaskmaster Posted July 28, 2009 Share Posted July 28, 2009 Always check/replace the cheapest parts first. Link to comment Share on other sites More sharing options...
dragstardave Posted July 30, 2009 Author Share Posted July 30, 2009 Turned out to be reg/rectifier thanks Ttaskmaster Link to comment Share on other sites More sharing options...
Ttaskmaster Posted July 30, 2009 Share Posted July 30, 2009 Let me guess..... and this is just a guess, now...... The ill-located L-Bracket that holds it to the frame had split, snapped or rusted through, providing a fucked-up earth? It's a common thing on the Drags. Where's Mikey? I just mentioned this, didn't I? Link to comment Share on other sites More sharing options...
Cov_AL Posted July 31, 2009 Share Posted July 31, 2009 Let me guess..... and this is just a guess, now...... The ill-located L-Bracket that holds it to the frame had split, snapped or rusted through, providing a fucked-up earth? It's a common thing on the Drags. Oh, you've had problems with that L-bracket too? I'm also on my second one - I think the reg/rec was an after-thought when they designed these bikes... Link to comment Share on other sites More sharing options...
Ttaskmaster Posted July 31, 2009 Share Posted July 31, 2009 Mine and Claire's have both gone at some point. It happens a lot. Trouble is that all the road crap gets kicked up off the front wheel, straight onto the bracket. There's a lot of weight bouncing around there on the thin metal and so eventually it goes. Usually just above the single bolt. When it goes, have a decent mechanic weld it back together back and front with some decent work. I do believe Yamaha fucked this up, along with locating the oil sight glass and a couple of other things. Understandable since the 650 (IIRC) was the first model designed to replace the Virago, with others following thereafter. The 1100's worst "design feature" is that you have to take off the exhaust to access the oil drain, though you can get an aftermarket adapter kit. Link to comment Share on other sites More sharing options...
king_3 Posted August 17, 2009 Share Posted August 17, 2009 i have got a dragster xvs125 and i have the same probs as you i was on my bike the other day when i smelt a sort of eggie smell only to see my batterie was very swollen and ready to pop i bought a new batterie today and only drove for 22miles and batterie was very hot i think this could be a rectifiyer problem Link to comment Share on other sites More sharing options...
dragstardave Posted August 20, 2009 Author Share Posted August 20, 2009 i have got a dragster xvs125 and i have the same probs as you i was on my bike the other day when i smelt a sort of eggie smell only to see my batterie was very swollen and ready to pop i bought a new batterie today and only drove for 22miles and batterie was very hot i think this could be a rectifiyer problem Hi King_3 yea could be test the reg/rect and see what voltage you got going into your battry Link to comment Share on other sites More sharing options...
king_3 Posted September 29, 2009 Share Posted September 29, 2009 yes i fitted a new rectifiyer and now all done there is a place in salford and sell rectifiyers for £49.00 incl p+p good value for money Link to comment Share on other sites More sharing options...
Joshua2 Posted September 30, 2009 Share Posted September 30, 2009 I dont have any experience with this particular model but I have come across this problem before with older British bike. 'Joseph Lucas - the god of darkness'. Perhaps as a safety measure a thick wire pig tail could be taken from the rect. mounting bolt and then to a good earth just incase the bracket breaks and you dont notice immediately. (Just a thought.) ATB J Link to comment Share on other sites More sharing options...
Moderator Airhead Posted October 1, 2009 Moderator Share Posted October 1, 2009 'Joseph Lucas - the god of darkness'. ATB J Perhaps as a safety measure a thick wire pig tail could be taken from the rect. mounting bolt and then to a good earth just incase the bracket breaks and you dont notice immediately. (Just a thought.) ATB J Good idea if its a known common problem. Link to comment Share on other sites More sharing options...
