wiring help for 91 FZR 600
Hi,
I have bought a 91 FZR 600 that has been prepped for the track. I need to fix the indicators on for the MOT. The indicator wiring has been taped up and I have found both the rear wiring and the front right side. But for the life of me I can't find the left side. I have stripped all the tape off to no avail. At the rear the wiring is green and black then brown and black. In the front for the right hand side the wiring is green and black. For the left side i have found on connector (green/blue), but no other. There is a 'male' block connector on its own with brown, black and red wire's going into it. Can someone help with the wiring of the left/front side indicator.
Cheers
Damian
i could be wrong but i dont think that you need indicators for an MOT, by what i mean is if they are on it they must work but if there are none fitted then its OK.
maybe someone else may shed some light on it, or phone the test centre and ask them.
good luck ;)
good luck ;)
Ive checked with an MOT station and if the bike is older than 1986 and came with indicators fitted then it appears you must have them but it is a bit misleading. Thanks for the reply though.
