Pharao Posted July 25, 2009 Share Posted July 25, 2009 This is not a question, but a little hint to repair the side covers, I've just tried it and it works. I've just repaired some serious craks on my sidecover this way. I did put some Acetone in a glas jar, after that i did put some lego bricks there in, after they were meltet, I just put the sticky stuff in the craks and sured there was pressure on the cover, put a little extra on the backside to make it a bit more strong. I've got this advise from a friend and it works. I've just tried to use the same way to glue a broken tap on the same cover, tomorrow I will know if that worked, as good as the other repair did. And now I can say: It worked on that too. I hope someone can use this cheap advise. Link to comment Share on other sites More sharing options...
Moderator drewpy Posted August 1, 2009 Moderator Share Posted August 1, 2009 good tip. some people melts tie wraps into the crack to weld a repair Link to comment Share on other sites More sharing options...
