Pepair of sidecovers
This is not a question, but a little hint to repair the side covers, I've just tried it and it works.
I've just repaired some serious craks on my sidecover this way.
I did put some Acetone in a glas jar, after that i did put some lego bricks there in, after they were meltet, I just put the sticky stuff in the craks and sured there was pressure on the cover, put a little extra on the backside to make it a bit more strong.
I've got this advise from a friend and it works.
I've just tried to use the same way to glue a broken tap on the same cover, tomorrow I will know if that worked, as good as the other repair did.
And now I can say: It worked on that too.
I hope someone can use this cheap advise.
