Divvy 900s
Hi All, new to the forum, new to biking and still grinning like a fool. Need a little help though. I'm looking to replace the front brake line with braded ones but all i can find are single lines, (my bike runs one from the master cylinder down to the left brake then has a solid tube over the mudguard into the right one) should i keep with this set up or run two seperate lines, what's standard? I also want to raise the bars a little so may have to go longer than the standard hose, whatever that might be. Any help or advice is welcome. Thanks
:welcome: to the forum Gaps
just buy a heli kit & junk the metal work over the front mudguard .. you get 2 lines & a longer bolt to the master cylinder ... job sorted !
Regards Jim
Regards Jim
Thanks for that, let's see how it goes....
