July 22, 200916 yr Hi all, I'm a newbie to the forum and I have a couple of questions relating to my XVS1100a I've had for six months. The bike is a 2004 Custom and I love it, but I don't love the soft suspension. I'm thinking of putting some progressive fork springs in, but would like to hear from anyone who has done it and what was the outcome. Next question relates to adjusting the preload on the rear shock, how is this done easily? Thanks
July 22, 200916 yr Rear shock should be easy. Whip the seats off to get at the monoshock and twist the adjustment collar using the special spanner provided. Check the owners manual for precise instructions. If you have neither of these things, they can be got from a parts supplier and downloaded from the links on this site, respectively. You might find that fiddling with the rear is all you need to sort out both issues. WRT the front; have you checked that the forks are in good nick first? Oil is good, seals are not leaking etc... It shouldn't feel that soft - unless you're riding fast over speed bumps?
July 23, 200916 yr Author Rear shock should be easy. Whip the seats off to get at the monoshock and twist the adjustment collar using the special spanner provided. Check the owners manual for precise instructions. If you have neither of these things, they can be got from a parts supplier and downloaded from the links on this site, respectively. You might find that fiddling with the rear is all you need to sort out both issues. WRT the front; have you checked that the forks are in good nick first? Oil is good, seals are not leaking etc... It shouldn't feel that soft - unless you're riding fast over speed bumps? Thanks Ttaskmaster for the reply. The front forks are in good nick i.e no leaks or other obvious damage. I could check the oil level. When I 'm on the bike, stationary and I bounce up and down there is virtually no resistance, its like a water bed. I'm thinking that's not normal.
