Oil Press Switch resistence
Hi all,
As I posted earlier my oil press. switch is not working. I took it out and tested it with an ohmmeter today and I got about 40 on the R x 1k scale. I'm not sure if it's normal or not.
Since there's no pressure the contact should be connected (grounded), hance, the ohms should be close to 0 (current can go through, lite up the indicator) .
Am I right?
Hi all,
Am I right?
Assuming it is a switch driving an oil warning light, and not a transducer driving an oil pressure gauge, you are correct. The switch, when under no pressure, should measure no more than a few Ohms. Under pressure, it should be open, or infinite Ohms. It is likely your switch's internal contacts are worn out.
