H4 bulb change in Dragstar 650
jenkovix
This post is 5498 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi Gents!
I would like to change the factory fitted H4 12V 55/60W bulb with a H4 12V 80/100W one in my 2008 Dragstar 650.
The original is not too bright. Also looking to get passing lights and a GPS. Will the electrical system will take the extra load?
Thank you
Yes, yes and yes.
I have the brighter bulb and a TomTom Rider2 linked in to mine.
I know someone else who has all three and then some.
I also run heated grips and a CB radio off mine.
However, it's worth getting a battery optimiser or similar charging system to keep things topped up.
Yes, yes and yes.
The final question is: is it legal to fit an 80/100W bulb? On the box says: "for offroad use only"...
If is says that, then no it's not legal.
TBH I don't know.
But I do see plenty of cars with FECKIN' BRIGHT headlights, so you might just need to swap the bulbs out once a year for MOT.
TBH I don't know.
There is no MOT for bikes in Ireland :D
Do I need to change any fuses?
Really?
No MOT?
Wow.... didn't know that.
Errrr...... fuses....... Maybe...... Don't know.
I didn't, but that doesn't mean anything :D
Really?
No MOT?
Did you change any fuse or simply swapped the bulb?
I just swapped the bulb.
That was well over a year ago, I think, and I've not had a problem to date.
OoOoOh! :idea:
I'd just figured I should eat more carrots...
Hmmm, might have to find one of those 80/100w bulbies :jossun:
  • 1 month later...
OoOoOh! :idea:
I changed to 80/100W bulbes, really lits up the road!!! :D
No any other change or alignment needed. Works jeeaah
Hi Gents!
Thank you
Hi just fitted one of these babies to my cat : Philips Motovision H4 Motorcycle Bulb
What an amazing difference
Mick
i was thinking of fitting one of these to my dt. its a 6 volt system but the headlamp puts out 11-14 v at driving speed.
the old headlamp lens assembly will accept one, and the light harness will hook to the bulb, but, will I fry my wireing, magneto, switch etc?
i want brighter lamp, but i refuse to do anything that will damage the rest of the bike as parts would be hard to find.
