alarm fitting R1
hi all newbie here have just got a minter R1 am about to fit an alarm/immobiliser, fitting manual say all yams have have a facility plug for this can anyone tell me where this might be before i tear the bike apart its a 2000 R1 cheers Rolls
  • 3 weeks later...
If the bike's an "import" it may not have the alarm plugs you're looking for....... assuming it's a UK bike, they will be found either against the rear nearside frame or under the seat next to the CDi.
You should find three little plugs -
One plug will have three wires comprising a 12V feed (from the "back up" fuse in your fusebox...... I normally change this fuse for a 10 or 15A while I'm at it!), an ignition feed and a negative feed.
Another plug will have two wires in it with a loop...... this is your ignition immobilisation.
The last plug will have four wires.......... another loop for starter immobilisation and the left & right indicators.
I chop each of these plugs off, wire by wire, as I solder my alarm/immobilisers in!
Get your test light out to make sure and call me up if you need help!
Pete 07877 552759
