If anyone can help i'd be very greatful.
I saved a DT80 from scrap heaven last year non runner. Apparently it did run until the magneto packed in
i got a second hand magneto with points and fitted it....no spark
Just wondering if its a CDI instead.... Anyway of finding out at low cost. Thanks
as far as im aware the only way to tell is to swap it for a known working unit and then check for a spark :\
depends where abouts you are from mate?
ebay is the best bet and available in most countrys, or maybe wemoto.co.uk, or bitzforbikez
so what was the first magneto, have you still got that one along with its backplate and coils etc? if there was no points in that one it is a CDI version isnt it?
1st one had points..thats why i got a replacement. will try and find a CDi part i think. thank you all
why not troubleshoot what you have, the cdi version (if there is one) will be expensive to convert to.
Has your bike got an ignition switch and a kill switch, if so unplug them both, (start with the kill switch) and check again for the no spark situation.
All thats wrong is the timing is out after the obvious (coil, wiring & switches) have been tested some where on here is a thread that runs the same ... I'll look for it & post a link
Regards Jim
