1974 DT360A Lighting
I have a '74 Dt360A which was restored last year. Suddenly, the turn signals and tailight stopped working. Any suggestions?
fuses? check the contacts as well for the fuses. A bike so old should have dirty connections, so if you cleaned them up and put some dielectric grease on the ends of the fuse it should prevent further corrosion from building up.
Your battery also needs a full charge for the lights to work other than the head light.
