July 13, 200916 yr Hi all. I have a 98 thundercat with 50k on the clock. Having probs going from 2nd to 3rd gear. The gear lever feels solid when i try. It goes into gear on 2nd or 3rd attempt. Any ideas please
July 17, 200916 yr Moderator Hi all. I have a 98 thundercat with 50k on the clock. Having probs going from 2nd to 3rd gear. The gear lever feels solid when i try. It goes into gear on 2nd or 3rd attempt. Any ideas please Firstly, post this up in the sports/streetbike section where you will get a much better response. Secondly i believe these gearbox issues are quite common in high mileage cat's i'm afraid, its not the first time i've heard of such.
July 17, 200916 yr Its fucked if it is what i think it is. 1000+ to fix cause you need to take the whole transmission to get at the problem. not worth fixing unless you have the skillz ursel. Just go from 1st to 4th, will use more fuel but you will have more fun!!
July 18, 200916 yr Its fucked if it is what i think it is. 1000+ to fix cause you need to take the whole transmission to get at the problem. not worth fixing unless you have the skillz ursel. Just go from 1st to 4th, will use more fuel but you will have more fun!! shit im thinking of getting one of those
August 23, 200916 yr here are all the awnsers to all of your questions http://www.yzf600r.com/phpBB2/index.php lol .. I also run out first gear and go straight to 4th
