Posted July 12, 200916 yr hey, Does anyone know where I can find detailed info about the MOT for bikes in the UK? Ideally some sort of checklist. cheers!
July 12, 200916 yr Author hey, Does anyone know where I can find detailed info about the MOT for bikes in the UK? Ideally some sort of checklist. cheers! you know what? ignore that - i just pulled my finger out of my arse: http://www.vosa.gov.uk/vosacorp/repository...0(VT%2040M).pdf http://www.ukmot.com/bike_index.asp
July 12, 200916 yr hey, Does anyone know where I can find detailed info about the MOT for bikes in the UK? Ideally some sort of checklist. cheers! Try here , this link should tell you everything you need to know.
July 13, 200916 yr the back of haynes comics also have quite a good checklist you can work through too. Get a mate to do the actual checks, so that they are unbiased, just like the real tester.
July 13, 200916 yr hey, Does anyone know where I can find detailed info about the MOT for bikes in the UK? Ideally some sort of checklist. cheers! Hi, What do you need to know ? Regards Jim
July 13, 200916 yr Author Hi, What do you need to know ? Regards Jim hey Jim, I think the links above have pretty much covered everything - will let you know if anything specific comes up. cheers everyone.
