July 10, 200916 yr Hello. I've got an SR125. My rear sprocket needs changing and reading my Haynes manual I'm pretty clear how I do that. However, I'm less clear on how I change the front sprocket (I've been tod these should be done at the same time). The only vague reference I can find in the Haynes is in a section entitled 'Removing the engine/gearbox unit from the frame', which talks about lifting up the fuel tank, diconnecting and removing the battery, removing the exhaust system etc, etc, before even getting to the front sprocket. I hope it's not that complicated. Can anybody help me out? Thanks.
