i have a dtr 2001 model and i just put a new engine in the and the only problem i gt is i cant remember where the oil line goes into the carb and i cant see enywhere it can go can eny1 help
the oil line doesnt go into the carb....... and there should only be one place for the fuel line unless u got the special carb with a feed around on it. also i got a port head for the old dt, i got a tzr and up[grading to the 185 kit £40 its yours with piston, rings head and barrel, has static powervalve fitted
