Posted July 2, 200916 yr Hi,can anyone tell me what causes the petrol tap to go tight,can it be fixed ? Or is it a replacement ? Need to sort it as it was so tight tonight i nearly had to use a pair of pliers on it!! Lol, Cheers Tim
July 2, 200916 yr could just be full of sh*t, take it out and give it a good spray through with WD40 and clean the filter screen whilst you're at it
July 2, 200916 yr Moderator I would have thought you could strip it down and give it a light clean with something, dont forget the metal is soft though so dont be too rough and rinse it clean before re assembly. Use a well fitting screwdriver on any screws so you dont round them off. If it gets much worse youre gonna break it, Goes without saying drain the tank before stripping...even though i just said it... ...Paul
July 2, 200916 yr Author Thanks for the quick replies,i will give it a go,shame i filled the tank up on the way home!! Oh well sods law i suppose!! Cheers Tim
July 4, 200916 yr Thanks for the quick replies,i will give it a go,shame i filled the tank up on the way home!! Oh well sods law i suppose!! Cheers Tim G'day mate. If it is the type of tap that has an O-ring, replace the O-ring. It swells and tightens up the guts of the tap.Paul.
