MVTECH Posted July 2, 2009 Share Posted July 2, 2009 I own a 1980 xs400 special, and recently i'ved encountered a little problem with the clutch, once i start the bike and after warming up i attempt to put the bike in any gear and it will go into gear but the bike will jump into gear, it will be like putting the bike into gear without engaging the clutch lever. And will cut the engine. I'ved checked the clutch adjustment by the book but no matter how many times i try the adjustment it will still do the same thing, please help... Thanks. The clutches and plates with cable were recently intalled. Link to comment Share on other sites More sharing options...
Moderator drewpy Posted July 2, 2009 Moderator Share Posted July 2, 2009 I own a 1980 xs400 special, and recently i'ved encountered a little problem with the clutch, once i start the bike and after warming up i attempt to put the bike in any gear and it will go into gear but the bike will jump into gear, it will be like putting the bike into gear without engaging the clutch lever. And will cut the engine. I'ved checked the clutch adjustment by the book but no matter how many times i try the adjustment it will still do the same thing, please help... Thanks. The clutches and plates with cable were recently intalled. its clutch drag, when you say adjusted is that just at the handle bars or the full adjustment? you could have a sticky cable, so lube it! there may be some rust on the clutch rod preventing full movement. or you might have rusted plates and just need to ride the bike or the plates have warped preventing them opening oe there may be grooves on the clutch basket preventing the plates moving there's a lot to go on to keep you busy for a while Link to comment Share on other sites More sharing options...
MVTECH Posted July 5, 2009 Author Share Posted July 5, 2009 its clutch drag, when you say adjusted is that just at the handle bars or the full adjustment? you could have a sticky cable, so lube it! there may be some rust on the clutch rod preventing full movement. or you might have rusted plates and just need to ride the bike or the plates have warped preventing them opening oe there may be grooves on the clutch basket preventing the plates moving there's a lot to go on to keep you busy for a while Thank's for the valuable info.... Will try all the above and post the results, thank's and regards Link to comment Share on other sites More sharing options...
Joshua2 Posted July 9, 2009 Share Posted July 9, 2009 Some models of Yamaha have a special order for the clutch plates to be fitted. I found I had no clutch on my FZX when I reinstalled the new plates in the wrong order. ATB Ian Link to comment Share on other sites More sharing options...
MVTECH Posted July 9, 2009 Author Share Posted July 9, 2009 After verifying all of the possibilities of the problem, iv'e found that the clutch push rod did have some rust and didnot have enough grease and it didn't allow it to operate correctly. Once that was taken care of it worked fine. Thank you all for the valuable info and the great tips.. This is one more reason why i love this site, Thank's again and greetings form Puerto Rico. Link to comment Share on other sites More sharing options...
