July 2, 200916 yr Hi everyone, first time post here. can someone tell me how to remove or bi pass the clutch switch on the lever? Both of the wires have broken off and I can not re connect them while in the housing. I don't want to break the switch getting it out, or can I bi pass it some how? Much thanks Jeff
July 2, 200916 yr Moderator Hi everyone, first time post here. can someone tell me how to remove or bi pass the clutch switch on the lever? Both of the wires have broken off and I can not re connect them while in the housing. I don't want to break the switch getting it out, or can I bi pass it some how? Much thanks Jeff potluck! it will be a simple open or closed circuit for the bike to work. follow the wires into the headlap and cut or join in there making sure the ends are isolated from other wires drewps
