yamaha dt125 power valve
i think thta something is wrong with YPVS. the YPVS electric engine is working but if the speed is like 6500 it stuck.
when i disconnected the cables and turn engine on and gave the gas it stucked same way like it stucked with YPVS engine.
i don't know what to do anymore, i have tried to do everything. :unsure:
whether there may be problem that i have old candle and or some electic issue ?
Hi Krew,
:welcome: to the forum
I don't quite understand what you mean .... is the ypvs not working at all or only opening @ 6500 rpm or in fact not altering at that engine speed your old candle = spark plug may need to be replaced but more info would be good
Regards Jim
i don't know how to explain this situation, my english is not that good too. ;)
i dont't know how the YPVS realy works but if i check it today i got smarter. if i have gearbox on neutral and i give gas the speed goes over 6500-12000 and then few seconds it wont go over 6500 and the valve like wont open anymore.
same thin happen when i drive with 4, 5 and 6 gear. with 1,2 and 3 its almost normal.
idk did u understand me. :mellow:
