Posted June 29, 200915 yr hey guys, Just rebuild my bike and i want to flush the oil out of the shocks, just wondering if anyone knows how much fluid must go back in for a stock setup? Also if anyone knows what the stock shock fluid weight is that would be helpful thanks for any help cheers
July 2, 200915 yr Moderator Your bike is 1988? in uk they were long finished before then. Where are you? maybe yours id different with being a much later bike
July 2, 200915 yr Hi Naten, I am rebuilding a 1988 DT200r ( 1997 on logbook !! hey this is Cyprus ) and have found I have to search dt125 manuals for parts common to both . I have 1988 owners manual for dt200 and workshop manual for 1988 DT 125 on pdf if you want them - www.dtr125.net/workshop-manualf.htm. If the forks are the same for 175 then you need 10w oil, 486cc , level 175mm from top of inner tube when fully compressed without spring Hope this helps . Regards Bob
July 2, 200915 yr Author ah i see im from austrailia downloading those pdfs now, your a champ. NFI if its the same though
July 2, 200915 yr If you are in Australia take a look here , there seem to be loads of DTs in Oz www.yamahait.com.au Bob
