strange noise form low down torque
this issue is regarding a xj600s 1996.
i have a strange clunking noise when i pull away and in second gear. thought it might be the chain slipping. so i lifted the back end and tried to spin the back wheel to find a broken tooth. but the wheel doesnt spin freely and makes a clunking noise as i role it round manually.
i checked to see if the brake pad is touching the disc and one side is and the other is 1mm off. not sure if this is normal.
i have no idea what the issue is and dont fancy getting ripped off for something that i could do myself.
any ideas welcome.
cheers
david
any ideas welcome.
cheers
david
sounds very much like a stiff/siezed chain link, better to replace it if in doubt, £70.
get the wheel off and check the large bearing in the sprocket carrier, check the drive sprocket while your at it
hope this helps :)
